Installation details for inner corner trim over rainscreen and foam
Does anyone have advice or details for installing exterior inner corner trim when using a rainscreen over foam? I’m trying to replicate the historical details on our house that used a 1″x1″ nailed into the inner corners and then butted the siding up to it. We’ve added 2″ of polysio and a 3/4″ rainscreen of 1″x4″ furring strips.
Do you just build a corner of 1″x4″ or 1″x6″ material to use as a nailing base, and nail the 1″x1″ into that corner, then screw the whole assembly to the studs through the foam? Or is there another approach that makes sense?
Nathan,
Whether you pre-make the whole inner-corner assembly , or just nail the individual pieces on one at a time is really a preference - both ways work well. When you install the siding remember to bed it in a bead of caulking against the corner trim as you go.
Will do Malcom - thanks for the advice!
