Increase size of Z-flashing if I need to add a slope between SmartSide panels?
![](https://secure.gravatar.com/avatar/15ea11eba3eeaf25c5478d7db23ba411?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
SmartSide 4×8 panels require the z-flashing on horizontal seams to be sloped slightly toward the outside, but I gather that z-flashing is made with right angles so that the seat would be flat, not sloped. For SmartSide that’s 3/8″ thick, should I buy 7/16″ or 1/2″ Z-flashing so that I can bend the seat into a slight slope (which would slightly reduce how far outward the seat reaches)? Or am I missing something, as it seems strange that this common use of Z-flashing would require it to be bent by the user?
Jeff,
The flashing is there to keep water getting into the top edge of the panel, no slope is needed (doesn't hurt, but not required). Just use as is. I would want the Z flashing to be pretty much flush with the top of the siding (just a bit more than the panel thickness) for cleanest look.
Thank you, Akos. I assume that the slope is intended to keep water from pooling on the z-flashing seat where, if it were deep enough, it could start soaking the bottom of the upper panel. If I were to use the flashing as-is, would your recommendation for "just a bit more than the panel thickness" be 7/16" or 1/2", or do they make the 3/8" a little bigger than 3/8" to allow a slight margin on 3/8" panels?
Jeff,
My experience is with the 5/16" thick Hardie panel. The min bend for my flashing shop is 3/8 so that set the size. The vertical gap was 1/4" , not much water would get stuck there.
I would get a piece made up and see how it looks.
Jeff,
Are you buying pre-formed flashing, or getting the pieces bent by a fabricator? If the latter, you can get any slope y0u want on the horizontal portion.
I agree, Akos, that the gap reduces the likelihood of water soaking into the upper panel. Perhaps there's also a concern that water would seep through the junctions of two pieces of flashing, but that doesn't seem likely to amount to much.
Thank you, Malcolm. I was planning to buy it off the shelf, where it's around $5 for 10 feet. I expect having it fabricated would be much more expensive. What size of pre-formed flashing would you recommend for 3/8" SmartSide if a) I intend to bend it and b) if I dont? Would you bother to bend it?
I don't think you would have much luck getting a useful or consistent bend unless you had your own break. I'd rely on a small capillary gap between the flashing and panel above and not worry about it.
Thank you, Malcolm. I was wondering how I'd bend it decently. I surmise that the slope they recommend may be ideal, but it's more than most would take the time and expense to implement.
