In a home with a copper roof, island location, off the east coast. Is grounding of the roof advisable?
Stephen46224 | Posted in GBA Pro Help on
If so, describe the recommended method. The building is 40 or so feet tall, surrounded by trees that brush the structure on 3 sides, and neighbors are within 30 feet both right and left. The building is not elevated compared to the surrounding topography. Thanks
  1. jklingel | | #1
    If you don't get an answer here, or want a second opinion, post here http://www.diychatroom.com/. There are pro electricians there. Good luck.
  2. Daniel Morrison | | #2
    You might also try the Fine Homebuilding discussion forum: http://forums.finehomebuilding.com/
