If you were to replace your windows what material would you use for the frame?
![](https://secure.gravatar.com/avatar/14a5c5c76d04a70f46630a4cf751adf3?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
If you were to replace your windows what material would you use for the frame? And would you use a double pane with argon?
These are replacement windows for a hot climate.
Janet,
If you plan to buy replacement windows, the upgrade from ordinary double glazing to low-e, argon-filled double glazing is always worth it. For more information on glazing, I suggest that you read All About Glazing Options.
Q. "If you were to replace your windows what material would you use for the frame?"
A. If price were no object, I would choose pultruded fiberglass.
Janet, if you aren't manufacturing your new windows yourself,
the choice of the brand/manufacturer might be more important than the material itself.
A specific material type doesn't assure you receive quality products.
Warranty, specs and performance rating is what you are looking for.
On the glazin side, double pane low-e + argon is probably the minimum you should settle for in 2014, if you are not offered this option ( which i consider bare minimum ) look elsewhere.
Also ask about price difference of triple pane as if it is lower than 10% you should also consider this option ( if your weather goes to extreme )
As Martin pointed out, Fiberglass frames as the highest performance possibility VS cost,
but brings the importance of correct manufacturing higher than others
( because of experience and material related difficulties )
