Ideal double stud wall?
![](https://secure.gravatar.com/avatar/55c62ae1633e277e7fb1f5d0cf3ddbcf?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fd.png&r=g)
What do you think is the best way to go about buidling a double stud wall?
Is it better to use spray foam insulation a couple inches thick, followed up by cellulose and let the exterior sheathing dry out?
My idea for a cost effective way to do this is double 2X4 wall approximately 10 inches apart. 2 inches of closed cell foam on the inside to stop water / vapor. Fill the rest of the cavity with cellulose then drywall it. Outside sheathing will just be normal tyvek housewrap with vinyl siding.
Is there a better more cost effective way to achive a similiar (R40 ish) insulation value?
Denis
Denis,
You are double posting. My answer to your question is the same as the last time you asked it. Skip the spray foam and fill your double-stud wall with dense-packed cellulose.
