I’d like to install recessed lights in my walk-in closet. Can I use non-IC lights?
![](https://secure.gravatar.com/avatar/70dbe0306f800130ab93e9740b0c081f?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fn.png&r=g)
There is thermal insulation in the attic. Is it possible to use NON-IC lights and create a border (kind of fake ceiling), if it is possible, what’s the mark spacing between this border and the insulation.
Natalia,
I strongly recommend that you don't install any type of recessed light fixture -- whether or not it is IC-rated -- in an insulated ceiling. These fixtures leak air.
If you want, you can create a suspended ceiling (a false ceiling or dropped ceiling) about 9 or 10 inches below your existing ceiling. Then you can install recessed fixtures in this lower ceiling if you want.
