ICF vs tradition framing.. cost comparison.
![](https://secure.gravatar.com/avatar/52886dfb4948a77d9a100d3f7c86128d?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
We’re having an addition drafted up. Some research has led to ICF costing about $220 per 4×8 of exterior wall.
I’m just not sure it’s worth it.
Traditional built,
5 2×6 studs – $34
7/16 zip – $30
3″ of polyiso between the studs = $30 (a local factory always has seconds)
= $94.
I could add a lot of additional insulation inside/out for the difference…
ICF is going to add additional costs at every stage of construction and throughout the life of the building.
When the plumber needs to make a hole for an outside faucet. When you want to install a doorbell or even a house number.
I agree. ICF can almost be justified for foundations, as it gives your concrete walls insulation as a part of the job. Still, the added labor cost of stacking ICF versus a skilled concrete crew setting forms makes the ICF tough to justify. Above grade, I wouldn't consider it except possibly in very high wind areas.
