ICF Addition Detail
I’m in the process of adding an ICF porch to my ICF basement foundation. The porch foundation will extend about four feet below grade.
The ICF manufacturer’s tech support suggested that I cut away the foam where the porch foundation will meet the basement wall. If the foundation depth between the two structures matched, I would be able to cut the dimpled drainage membrane and the adhered waterproofing membrane and wrap a new piece neatly around the corner. Since I won’t be escavating to the full basement depth, I would have to notch or split the membrane horizontally, which seems like an invitation for water infiltration.
Do I really need to have concrete-to-concrete contact?
To avoid water intrusion, I would prefer to dowel the porch foundation into the basement wall with 12 pieces of #6 rebar, and place concrete directly against the drainage membrane. Since the foam is only 2.5 inches thick, I think the rebar could still serve the purpose of preventing separation or differential settling. The walls will be well reinforced, and they will be tied together with a slab on composite steel decking. I think I’ll probably turn the rebar from the walls into the elevated slab.
I would appreciate your opinions.
Ben,
I'll give your post a bump.
