I would like to insulate the attic rafters but I would like to keep the rafters visible for a decorative look
![](https://secure.gravatar.com/avatar/2be550907c5b2c0c4b6256c34f5e1db9?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
Are insulation boards available with a wood look to them? I saw something on the internet that had that look but have not been able to find what i saw
Jorge,
I don't know what product you saw. I am not aware of any insulation product that looks like wood.
If you want your rafters to be visible from the interior, the usual insulation method is to install one or more layers of rigid foam insulation above the roof sheathing, followed by a layer of OSB or plywood and new roofing. Of course, this requires you to install new roofing, so it's expensive.
