I want to install a GE Profile gas cooktop over a GE Advantium oven
![](https://secure.gravatar.com/avatar/d43388bb86a853779757a2e8b177aea5?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fr.png&r=g)
The cooktop will be layed on a standard granite top, and the oven, which is electric, will be installed in an existing 30″ base cabinet. Is there any special material I need to use to insulate the oven?
As I have never mounted an oven under a cooktop, and with the top being gas, I want to make sure heat build up won’t be a problem. I also am concerned with the gas line that will have to run near the oven!
Thank you for any help with this!
I'd check your situation with the manufacturer and/or dealer; they should know. There are some pretty handy cats here, too. http://www.diychatroom.com/
