I applied rigid form insulation to the inside surface of the existing sheetrock in a bedroom
![](https://secure.gravatar.com/avatar/d593c0af4cd787cf327ba8249e8176d7?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fr.png&r=g)
Prior to placing the insulation, I glued heavy fabric to the front to give it an aesthetic balance with the bedroom.
My concern: Will the form board out-gas causing harm to the occupants?
Robert,
Q. "Will the form board out-gas causing harm to the occupants?"
A. Probably not, but the rigid foam is definitely a fire hazard and a code violation. Building codes require rigid foam to be protected on the interior by a so-called thermal barrier equivalent in performance to 1/2-inch drywall.
In almost all cases, the easiest material to use for this purpose is 1/2-inch drywall, so that is what you should install to cover your rigid foam.
Oh! I see your point and much appreciated. I feel compeled to remove from the one wall since my 17 year old occupies the bedroom. Thanks for the quick response.
