Hurricane preparation work is evolving
![](https://images.greenbuildingadvisor.com/app/uploads/2018/08/08123500/martin-holladay.jpg)
Here’s a photo showing a worker in Florida preparing for Hurricane Dorian. (The photo appeared in today’s New York Times.) He’s installing plywood on a storefront.
Twenty years ago, this task involved nails or screws. These days, the smart people are also including peel-and-stick tape. Good job!
Is that you, Martin?? Did you retire down there? :-)
Assuming there is a waterproof window behind the plywood, why? But OK, maybe there isn't or won't be.
Hmm, looks like Dap Seal’n Peel is useful for closing up window/door gaps.
Jon R:
Flying debris
Only a really well-built window will stand up to extreme wind pressure, but they do exist. They do not make them to deal with the impact of 2x4 missiles, though.
Typically the way a home gets leveled by wind, when they do, begins with a window or door failing, and pressurizing the house like a parachute, lifting the roof off.
Additional sheathing helps with both things.
