HRV – Heat Recovery vs Fan Efficiency Question
![](https://secure.gravatar.com/avatar/08f9d15c85015cef9bfce714d8c5874f?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
I’m trying to decide on an HRV for a tight house in Zone 7A, heated by a ccASHP.
Our HVAC installer has given us two options available at his supplier. A Vanee and a Fantech unit.
The Vanee has an ASRE of 78 to 67% efficiency, while the Fantech has an ASRE of 87 to 69% (see image below). The Fantech unit does not use an ECM however, so the fan is 30-70% less efficient.
In a situation like this, which would be the better unit to go with. One that is up to 10% more efficient at retaining heat, or one that uses less power for the motor?
Fantech do an ECM version of their product (in the spreadsheet attached), but it’s over $1000 more from the HVAC installers supplier, so I don’t see it as being economically feasible.
if I remember correctly, ASRE includes fan power whereas SRE does not (or did I get that reversed)
this doesn't answer your question.
this trade-off probably begs for some modeling or at least some temperature bin analysis.
