HRV ducts in a slab-on-grade bungalow
![](https://secure.gravatar.com/avatar/92bad00094f7c52c5abb23d47f59ce3c?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
Hi,
I am designing a ~2000 sq. ft. slab on grad bungalow home which will hopefully be airtight (below 1 ACH) and very well insulated with grid tied PV (net metering). I am located in Ottawa, Canada which I believe is a climate zone 6A.
Currently I am researching and educating myself regarding various heating (ductless mini split) and HRV option. The dilemma I am running into is not wanting to run the HRV ducts into the attic for the many reason most of you already know. Other than creating a ceiling service cavity below the insulation/air-barrier, are there any other options?
Thank you
Soffits at the crown-moulding level can work. The duct sizes are pretty small.
https://basc.pnnl.gov/sites/default/files/styles/large/public/cad-previews/331_CAD_5-3_dropped_soffit_5-01032_GBA_1-31-12_0.jpeg?itok=IZfRo6W-
https://www.greenbuildingadvisor.com/sites/default/files/images/5-01022.png
The same soffit can be used for mounting wall-wash and other downlighting fixtures. Be creative!
Arnold,
Here is a link to an article that addresses your questions: Keeping Ducts Indoors.
Thanks for those ideas/links Dana. My wife who studied Interior Design and Sustainable Building and will likely have a field trip coming up with creative ideas to hide HRV Ducts.
I am also wondering if installing a few Lunos HRV would be worth considering even though I suspect pricing wise it would be similar or more compared to a traditional ducted HRV system?
http://www.lunoscanada.com/lunos-e%c2%b2.html
Thanks Martin for the link
Arnold, Lunos' offerings are made for your situation. You might also want to look at the Zehnder 70 spot ventilation device. http://zehnderamerica.com/zehnder-america-announces-the-new-comfoair-70-energy-recovery-ventilation-unit/
