How to seal a stud wall addition on log cabin
![](https://secure.gravatar.com/avatar/8eabe16902a56c5f21aba7da6f6598ef?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fe.png&r=g)
Hello,
We’re adding a stud wall addition to a log cabin. The addition has 6″ walls, Rockwool, Intello + on the inside, Mento 1000 outside, 2″ Comfortboard, and then Hardie siding.
I’m wondering how I should seal the addition where the stud walls join the cabin. Should I just tape the vapor barriers to the existing log wall? Or should I caulk first, etc.?
Thanks.
eorr,
I have done framed additions to Panabodes, which are log structures with (fairly) squared off logs.
I fastened a 1"x6" to the logs, and ran a router up them to cut a groove that the sheathing would fit into. I then did the same where the drywall would be on the interior of the wall. This made the transition and sealing fairly easy.
Thanks, Malcolm, that sounds like a great way to handle it. Unfortunately this is an afterthought and I already have my walls butted up to the cabin. I think I can still do that for the inside but maybe spray foam would work for the outside?
