How to Safely Remove Dimethyl Fumarate (DMF) from a Sofa?
ASmak | Posted in Interior Design on
Hello everyone,
I recently purchased a new sofa, and I’ve noticed a strong chemical odor coming from it. After doing some research, I suspect it might be dimethyl fumarate (DMF), which I’ve read can cause skin irritation and allergic reactions. I’m concerned about the health risks and want to remove this chemical safely without damaging the sofa fabric.
Does anyone have experience dealing with DMF on furniture?
I’d appreciate any advice, tips, or recommendations. Thank you in advance!
  1. walta100 | | #1
    I am afraid any cure is worse than the disease. Any solvent that would free the chemicals would be at least as bad as what you have and only dilute and wash it deeper into the padding.
    My guess is this fabric is dangerous without the flame-retardant chemicals.
    Try putting it outdoors in the sun for a few days and maybe that will make it tolerable.
    Reupholstery is an old fashion option.
    BILL WICHERS | | #2
    I'm not sure if this is spam or not, which is why I didn't reply earlier.
    My recommendation would be to let the unit air out, so keep it in a well ventilated area, ideally with cross flow ventiallation (in one side of the room and out the other). Keeping the sofa warm during that time will speed up the process.
    Most of of the volatile materials that people worry about will come out on their own over time, which is what makes them "volatile". The trick becomes waiting long enough for the majority to dissipate. Normally this only takes a few days and the smell will significantly subside over that time.
    I'd be very reluctant to try any neutralizing chemicals, which, if not applied in exactly the right proportion relative to what you're trying to neutralize, will themselves remain on the sofa. Now you've just traded one thing you don't want for another.
