How to reduce the power consumption in our office
![](https://secure.gravatar.com/avatar/df86aa1c3e955388f55cf2b542ae1960?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fe.png&r=g)
I have been working as a research paper writer in one of the leading online research writing service website named [web site name deleted by GBA editor] for the past 5 years. Due to global climatic change, our company has been facing a huge power cut problem and fir generator itself for the last year a lot money has been spent. So, I request you all to suggest us a best solution for this power cut problem. I request you all to suggest us a best alternative power production method or source which should be in a minimum and manageable amount.
Elias,
1. I suspect that this question is actually spam designed to promote your company. I may be wrong.
2. If you are working for a top-notch research company, I'm surprised that you can't answer your own question.
3. The answer to your question is: As long as your building has good solar access, use PV.
And use laptops so you can continue working when the power goes out.
