How to populate Manual J lookup tables
Maine_Sawyer | Posted in General Questions on
Hi Folks,
Can someone point me to the data I need to populate the Manual J lookup tables (Walls, Glass, Doors, etc..)?
Thanks,
Larry
  1. Maine_Sawyer | | #2
    Thanks DC...I guess I didn't really ask the right question...I don't need to populate every possible option..only need to model my intended construction options..
    So I think my real question is this:
    I'm only concerned calculating heating load so I believe that for my walls, ceiling & slab Manual J only needs to know overall U values for theses components. So I should be able to calculate these based upon my assembly type and then populate the lookup table accordingly.
    For windows/doors I should be able to use manufactures U data, right?
    Thanks,
    Larry
