How to insulate the wood-framed section of a stepped basement?
![](https://secure.gravatar.com/avatar/402208907fdb8a119a5e6fc91c2851e3?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
We will be putting foam on the outer and possibly inner surfaces of our basement but I am wondering how to insulate the above-ground stepped (wood-framed) section of the basement.
Jessie,
If it's a wood-framed wall, I assume it is an above-grade wall. It should be insulated like any other above-grade wall.
Just follow the usual continuity rules: where the concrete walls meet the wood-framed wall, maintain air barrier continuity and thermal barrier continuity.
For example, don't leave any exposed concrete on the insulated side of the concrete -- cover it all up with insulation, and make sure the insulation on one wall connects with the insulation on the adjacent wall.
