How to insulate existing attic wall adjacent to heated space?
Existing attic exterior framed walls are uninsulated. 2 attic framed walls adjacent to upstairs heated bedrooms are insulated with batt insulation (vapor barrier at warm side). Batts are between the studs and exposed on unheated side.
Question: Can I add foam insulation board to the unheated (attic) side of these walls to increase R value. What type would I use to avoid creating moisture issues? Perhaps add foam insulation board over 1x or 2x furring on studs to create air space? Thanks for the help.
Assuming the unheated part is vented to the outdoors, you'll be moisture-safe putting rigid foam on the unheated side if you follow the IRC prescriptives for exterior R-value for wood sheathed exterior walls:
http://publicecodes.cyberregs.com/icod/irc/2012/icod_irc_2012_7_sec002_par025.htm
The type of foam doesn't matter, only the total R-value, but it does have to be covered with a fire-rated thermal barrier to be fire-safe. (Half inch wallboard works, painted or not.)
If the batts have polyethylene or foil vapor barrier there's a small risk if you create a moisture trap with foil-faced foam. If the only vapor retarder is a kraft facer, it's not a problem, since kraft facers become semi-permeable to water vapor if the moisture levels rise to mold-growth levels.
You DON'T want to create an air space between the rigid foam and the wall. An air space is just a thermal bypass, rendering the foam less effective.
