How to improve the walls for a 1000-square-foot house near Asheville?
![](https://secure.gravatar.com/avatar/3a5ec62798c165ab50fea52147da0736?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
What would be the best way to improve the walls in a 1000-square-foot house that currently has 2×4 walls with fiberglass batt insulation covered with OSB, felt paper, and vinyl siding?
I want to replace the vinyl siding with fiber cement plank siding, and thought this would be a good time to add some XPS insulation between the OSB and the siding. The felt paper undoubtedly will be damaged by removing the vinyl siding, so I am guessing I need a house wrap (Tyvek or other) and then the XPS sheets.
Should the XPS be taped at joints and windows and doors? Do I need a rainscreen gap between the XPS and the siding? The exterior walls are sitting on a concrete block foundation, and there is a crawl space under the floor.
Stuart,
Q. "Should the XPS be taped at joints and windows and doors?"
A. It's a good idea to improve the airtightness of your wall assembly when you do this work, so I would say yes.
Q. "Do I need a rainscreen gap between the XPS and the siding?"
A. I think it is a good idea. Here is more information on the topic: All About Rainscreens.
You probably also want to read this article: How to Install Rigid Foam Sheathing.
