How to find/vett energy retrofit contractor in Seattle?
mrjohn | Posted in General Questions on
I have a 1930’s brick veneer tudor home in the Seattle region.
My home is not very comfortable in the winter as it has some significant energy related issues that I would like to address.
I need help identifying what should be done and it what order, and help executing the work.
– Significant air leakage issues, especially around windows, given a unique design (general air sealing and potential window replacement)
– Home has no insulation in walls. Just brick veneer, 2×4 framing and then lath and plaster.
– Attic could use insulation help
– I would like to retrofit ductless minisplit heat pump to transition off fossil fuels, reclaim headroom from duct work in basement, and provide better heat/ac distribution through home
Can anyone advise on how to identify and vett the best contractors to manage these kinds of projects?
