How to enter a VRV system into REM/Rate for a HERS
![](https://secure.gravatar.com/avatar/01222742cba8531d01bbb013a646d1c0?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fk.png&r=g)
I am working on a mulit-unit, multifamily building that has several VRV systems. I am only modeling a single living unit for each floor. The unit that I am entering has two (2) VRV outside units tied together which runs the 1 inside unit for the living area I am entering. There are 9 inside units throughout the floor.
The model numbers are REMQ96PTJU and REMQ72PTJU. Since the units act somewhat like a ground-source heat pump, that is what I have entered. The only issue with that is there is a significant variation in the HERS when entering the # of wells, and trench length, and flow. I also tired to enter it as an air-source heat pump but all the specs gave me were EER and COP.
How do you enter VRV systems into REM/Rate and get a reliable HERS?
Have you tried posing this question to Rem Rate support?
I have had success with this contact:
Brian Christensen
There are also a few good RESNET related groups in Linkedin that might be a good source for advice.
