How to calculate soil heating storage capacity?
![](https://secure.gravatar.com/avatar/cebd215368346de70e1267194afe9707?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
I need to know how much heat in BTU can I store in a specific volume of a soil. I am using the underground soil of greenhouse as thermal mass storage. Right now I just know the volumetric heat capacity. But I want actual number of BTUs that I can store inside the soil. Do I need to measure the temperature variation through out the soil and then calculate the heat storage capacity?
Soils differ in the specific heat, and the specific heat varies with moisture content. Most soils have a specific heat between 800 and 1500 Joules per kilogram per degree C, depending on type of soil and it's moisture content. That means, to change the temperature of a 1 kg of soil 1 degree it either absorbs or releases 800-1500 Joules.
It's really the mass (not volume) and the average temperature increase/decrease that determines the amount of energy stored/released.
Dana: What would we ever do without you? You're a real Joule:-)
Shukriya, bhaisaab! :-)
