Paint Permeability for Clapboard
jsbb | Posted in General Questions on
I have a 150 year old house. I recently removed the aluminum siding and am restoring the original wood clapboard. I presume I should use a breathable / permeable paint when it comes time for painting. How permeable should it be?
  1. kbentley57 | | #1
    Most modern acrylic based exterior paints are very permeable, and durable.
    Benjamin Moore's "Regal" line is quoted at ~50 perm
    https://media.benjaminmoore.com/WebServices/prod/assets/production/datasheets/TDS_0103/20210706_W103_TDS_US_OKF.pdf
    Sherwin Williams doesn't seem to share that info in their tech docs, but I'm sure it's up there too.
    There's not a lot of control in choosing a desired permeability - just go with a good paint, apply it well, and it'll perform as good as anything else you could have applied.
  2. jsbb | | #2
    I believe Sherwin Williams puts their Super paints at ~27 perms and their Emerald at ~29 perms. Is that sufficient?
  3. kbentley57 | | #3
    Yes, that is sufficient.
    Anything over 10 perms is considered to be very vapor-open, and will allow drying when the conditions are right.
