How much exterior insulation on Basement wall to prevent condensation?
JayMart | Posted in General Questions on
Climate Zone 5 – I have 2″ of EPS on the exterior of my foundation walls. Although the brick shelf  (above grade) I have is not insulated. Is 2″ enough to keep my walls warm enough to prevent condensation from forming?
From what I understand we want more than 50% of the entire r-value of the wall assembly to be on the outside to prevent condensation. In this case, I have R10 of the total required R19.
I ask because I need to decide if I’m going to apply a vapor barrier to the inside part of the wall assembly (with either Closed Cell spray foam or a liquid applied vapor barrier and w/1″ of Dow Thermax.)
Any advice on what I should do in this situation?
Thanks
  1. Malcolm_Taylor | | #1
    JayMart,
    This article has the amount necessary by climate zone.
    https://www.greenbuildingadvisor.com/article/three-ways-to-insulate-a-basement-wall
