How far to go for a tree house / elevated play house?
![](https://secure.gravatar.com/avatar/8e937680cc3184756d28bd9aa6156ba0?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Ft.png&r=g)
Planning to build a ~120 sq. ft. play house roughly 10 ft. up in the air in our backyard.
Would like it to be sealed up from the elements & built somewhat close to home construction standards, but debating on how far I should take things like air sealing & insulation in a structure that doesn’t have HVAC or a mechanical ventilation system.
Anyone worked on any similar projects at building play structures similar to houses?
From a general perspective, the guidelines on insulated wood framed floors would seem to apply:
https://www.greenbuildingadvisor.com/article/insulating-a-wood-framed-floor-assembly
Timothy,
Are you intending to heat the structure?
As mentioned, no HVAC planned.
If I can come up with something cheap & simple that doesn't require a connection to the grid, it might be doable as a future project, though.
For right now the priority is more spring / summer use and trying to keep it naturally a little cooler than the outside weather here in Michigan.
With the shaded area beneath, would leavings things uninsulated / unsealed below result in cooling via the stack effect?
Without active cooling, I would think that insulation is going to have minimal effect (with the exception of the roof and surfaces getting a significant amount of direct sun). A vented attic with insulation above the ceiling would be best. Passive cooling through air flow is what you want. And on that note, you certainly don't want to air seal such a small abode without having a ventilation mechanism in place.
Timothy,
Sorry for the confusion - HVAC is typically is used to describe the mechanical delivery of heat and ventilation through air. No HVAC doesn't mean no heat.
As Bill said, there isn't much point in insulating or air-sealing if you aren't conditioning the space. Doing so will make the building assemblies less resilient to moisture damage. I'd concentrate of detailing it to resist bulk-water intrusion, and leave the floors, roof and walls as open as possible.
I would not bother with insulation if you won’t be conditioning the space. You can help a LOT with keeping it cooler by putting in a ridge vent to let hot air exit naturally out the top.
If I were building this, I’d go for a rustic look. I’d leave the interior walls open (studs exposed), and no ceiling so the roof would be a the ceiling with a vaulted interior look. This makes for a simple and open structure. If I was going to do any finish step, I’d paint it for a whitewashed interior look. Make sure you have some screened windows/doors or some other way for cool air to enter low in the structure. You want to provide some ways for cool air to enter to replace the warm air that exits out the ridge vent.
Make sure to “seal” things for bug protection. Sometimes this means tight fitting parts, sometimes you need to use fiberglass window screen as a BRB — bug resistant barrier.
I guess in my mind, I've mentally associated HVAC with any of the component parts not just air-based systems -- i.e.: no HVAC = no heating, no ventilation, no air conditioning.
Summarizing some of the notes so far:
- No insulation
- Caulk most seams to prevent bugs from entering
- Ridge vent for air to exit
- Some type of screened vent(s) on or near the floor for air to enter
Timothy,
A fruitful exercise might be to imagine what would make it easier to insulate the play structure later, and incorporate those things into the initial build. A sort of future-proofing for when you might find it a delightful spot for a study, or a quiet refuge for your children when they are a bit older.
Recently I've been designing a series of small backyard structures for use as B&Bs. As part of that process I've tried to have the clients imagine what the building will be used for when (or if) they tire of paid guests.
If you frame the structure to code, using standard stud spacing and wall/door dimensions, for example, it will be much easier to insulate or otherwise modify in the future. If you build as I described earlier, for example, you end up with basically open studwalls with only exterior sheathing so you essentially build up a structure that will withstand weather and then stop. It’s like getting a new home build ready for weather but never doing the interior finishes, for example. It’s pretty easy to start back up and finish the interior with a project like that.
I would want to get the windows and door to be flashed water tight to prevent rot. I see adding insulation and drywall as something that could trap water and lead to rot and mold.
I would allow for easy venting of hot air out the top and insulate the roof. Though you don't need massive insulation, R10-20 is more then sufficient. Go with foam above the sheathing and below the shingles. Use recycled foam to save on cost if available in your area.
The reason for venting off the top is to take advantage of the stack effect at night, if you have a closable/openable vent one can use it to let heat out and get come convection cooling. And an air source near the floor, on the opposite side of the vent so air has the longest possible travel path.
To be sure, in blackjack, card counting can lead a player to triumph. However, with regards to baccarat, there is basically no such trust in card considering a successful procedure that can prompt a success. Such correlations in card including in various games, including among blackjack and baccarat, shows up simply because the games are to some degree like one another. In any case, experienced players are in no rush to involve comparative systems for playing different games, and here's why.But, obviously, there are contrasts in card including in blackjack and baccarat https://www.9winz.com/home/blog/baccarat-card-counting-tips-and-tricks . Card including is a decent arrangement in blackjack. The 10 cards in the player's hand generally increment the possibilities winning. Why? There is a decent opportunity that blackjack will be in the player's hand a lot quicker (21 focuses). Also, with cards of group 10, the player feels considerably more sure multiplying the bet. While playing blackjack, players pick a methodology where cards with a low worth, for instance, two or four, ought to be taken out of the deck, and cards with a high worth ought to stay in the deck. Depending on the how-low framework, the player adds +1 assuming that cards from 2 to 6 drop out, and nothing ought to be changed if cards from 7 to 9 fell in the arrangement. What's more, you really want to deduct - 1 from the count on the off chance that cards with a presumptive worth of 10 fell, from 10 to ace. Card counting like this can assist the player with pursuing the ideal decision in blackjack. While in baccarat everything isn't so particularly basic as it would appear from the start, regardless of whether you contrast these games and one another. You really want to score 9 focuses in baccarat, which ought to drop out in the initial two cards of the arrangement. Yet, there are no extra installments for exemplary baccarat, which is ordinary in blackjack. In baccarat, cards from 2 to 4 assistance the player, while cards from 5 to 9 agree with the broker's stance. Yet, this data is probably not going to help the player, thusly it isn't exactly important. James Grosjean, a betting master, accepts that the cards in the baccarat format are excessively even, so they don't give clear benefits aside or the other. Along these lines, it is not really worth squandering life on card counting in the event that this technique isn't generally so viable as, for instance, in blackjack.
