How do you protect from termite or carpenter ant infestation between the sill plate and an ICF basement? I am in zone 7b.
FishMontana | Posted in Energy Efficiency and Durability on
The termites could use the foam as a pathway into the house. Without stripping the foam from the top part of the basement wall, how are the termites forced to the exterior?
  1. GBA Editor
    Martin Holladay | | #1
    Tadd,
    Code requirements for termite protection vary widely, depending on your location. I suggest that you contact your local code official and the manufacturer of the ICFs that you will be using.
