How do I set up more than one CoolCalc solution
![](https://secure.gravatar.com/avatar/124ede1ae81bb68c12bca44c863348d9?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fb.png&r=g)
Hello,
I was testing out coolcalc and I got a solution for a 5 ton AC unit. I’d like to run that same scenario – same house, same insulation etc but test with a 2 ton and 3 ton unit with slightly different specs.
I’ prefer not to have to enter all the info again.
Also I’m not familiar with latent cooling efficiency – can you tell me where to get that – it isn’t in any of the ERV specs for two different units I looked at.
