How do I repair this mudsill joint?
![](https://secure.gravatar.com/avatar/00fd4788ca581a5e7e411ca129e202f2?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
AlanB4
| Posted in Energy Efficiency and Durability on
It looks like there is some kind of parging that is now crumbling, i could break it apart with a screwdriver pretty easily.
TIA
Alan,
If you can "break it apart with a screwdriver pretty easily," then you should break it apart with a screwdriver.
Then vacuum up the chips and dust.
Then seal the crack. If the crack is wide, seal it with canned spray foam. If the crack is narrow, seal it with a high-quality caulk.
Thanks Martin, i have been resisting the urge to harm it and have been trying to preserve it.
Most if it appears to be seal-able with a thick bead of caulk, is there a particular type to be used here?
