Removing Old Boiler
Sam2112 | Posted in General Questions on
How do I remove an old oil boiler?
I have a 2006 New Yorker boiler and hot water baseboard system I need to remove. My HVAC company is removing the tank, and I’ll be scrapping the copper pipe, but I can’t seem to find instructions on how to disconnect and remove the boiler itself anywhere.
Does anybody have experience converting from oil hot water and removing the equipment?
Thanks!
  1. MartinHolladay | | #1
    Sam,
    A sledgehammer and an angle grinder are handy. Make sure there is no asbestos! If you think there might be asbestos, call a certified asbestos remediation contractor. Here is a YouTube video to show you what you are facing:
    https://www.youtube.com/watch?v=ofizFanAqnQ
    DCcontrarian | | #2
    Once the radiator pipes are removed, the boiler has the following connection points:
    * 120V electric supply. If there is a junction box you can cap this there, otherwise disconnect at the panel.
    * Thermostat wires. I'd leave in place for future use.
    * Fill water hookup. This should have an on/off valve. Cap the pipe past the valve.
    * Chimney. Unless it's being re-used this needs to be capped.
    The boiler itself is a big block of cast iron. Usually it's easiest to take it away in pieces. As Martin notes you can break it up with a sledgehammer or cut it up with an angle grinder.
    It's going to be messy, the boiler is full of water and rust.
    1. Sam2112 | | #5
      Thanks for the help. Just coming back to report everything went surprisingly well. My house is pretty small so the boiler was heavy, but manageable with two people and a good refrigerator dolly!
  3. walta100 | | #3
    I can’t help myself so what are you replacing the boiler with?
    If the boiler was manufactured in 2006 it is almost brand new by boiler standards reselling it is a possibility.
    1. Sam2112 | | #4
      We converted over to a hybrid furnace with a heat pump and propane, with forced hot air. The house is pretty small and it's a full gut job so it wasn't to hard to put ducts in while we had everything open.
