How do I prevent overheating in a 2nd floor (cost effectively)?
tydotten | Posted in Green Building Techniques on
I am trying to help someone problem solve and over heated 2nd story here in Portland, OR. This person has central A/C, but doesn’t like using it and it doesn’t effectively cool the 2nd floor as well. The house has vaulted ceilings, which makes adding a 2nd floor return in the ceiling cost prohibitive.
The client is open to a wall mounted fan. Given that we live in a heating climate, does anyone know of an insulated wall mounted fan that would work for this application (2×6 walls).
Any other bright ideas?
  1. GBA Editor
    Martin Holladay | | #1
    Tyler,
    There are two possible approaches: using an air conditioner, or using a fan.
    It's unclear from your question whether the client doesn't use the air conditioner because it is ineffective, or because the client doesn't like air conditioning. The first case is a problem that can be solved; the second case is not a problem.
    If the client prefers a fan, the obvious choice is a ceiling (paddle) fan. Needless to say, a fan won't lower the indoor temperature. To lower the indoor temperature, you need an air conditioner. If the current equipment isn't working, diagnose the problem and fix it.
    Dana Dorsett | | #2
    Ducts designed for heating don't always work as well when doing double-duty as air-conditioning ducts, especially in lightly insulated 2 & 3 story homes.
    Rather than a wall-mounted fan, a 3/4 ton ductless mini-split heat pump with a wall mounted cassette would do it , but it's a pricier option. At low blower speed they're quieter than a refrigerator, unlike most ducted AC systems, and a better one would be 2x or even 3x as efficient as central AC. A full heat pump version is a few hundred more than an AC only version, but would cost less than heating with natural gas during the shoulder seasons.
