How do I know whether the finish on a hardwood is safe?
![](https://secure.gravatar.com/avatar/f5571869fa90e018a9d18c33f7622cbe?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fw.png&r=g)
We need to rip up our carpet ASAP because my mom told use to use scotch guard and we and our 5 month old little baby have had health problems for five months.
We were thinking of having lumber liquidators install hardwoods bc we can only afford around 8,000 for the materials and labor for a 1500 sq ft home in Greenville sc.
What is a safe hardwood? Unfinished? If we get pre finished how do we know it is safe?
We are concerned our son might develop autism because he has showed signs of regression and we need to eliminate as many toxins as possible from the home.
Thank you
Wendy
8642930449
Wendy,
I have never seen any evidence that floor finishes (for example, polyurethane varnishes used to finish hardwood flooring) are toxic once they have cured. However, if you have any specific medical questions related to your son's symptoms, you should direct your questions to a pediatrician, not to a construction or green building forum.
You can certainly install unfinished hardwood if you want. Maple has been used for children's toys for hundreds of years, and is the preferred species for building blocks and other toys.
Unfinished hardwood flooring needs to be sanded after it is installed. If you don't finish it, it will show stains and get dirty. However, you can always clean the floor with a broom or a vacuum cleaner. Just don't expect the stains to go away.
