How do I air seal a wall cavity?
I am looking for a cost effective DIY way to air seal the inside of a wall cavity during new construction. I am sure this has been written up someplace on this site, but I cannot find it.
Caulking the studs to the sheathing from the interior side with acoustic sealing is pretty straightforward stuff (but buy a powered caulking gun, eh?)
An air-tight drywall primer lives here:
http://www.buildingscience.com/documents/information-sheets/air-barriers-airtight-drywall-approach/files/bscinfo_401_airtight_drywall_approach.pdf
Note, the harder part to seal well at the gypsum layer is the electrical boxes, but there are purpose-made flanged boxes available designed to be foam-sealed, eg:
http://airfoilinc.com/demo/demo.html
Using fire-block foam or caulk to seal the electrical penetrations of wiring runs through studs and stud plates is also a high-value/low-cost air sealing enhancement.
Eric,
The two most common techniques used there days are the sealed sheathing method and the Airtight Drywall Approach.
Here's an article on sealed sheathing: Airtight Wall and Roof Sheathing.
Here's an article on the Airtight Drywall Approach: Airtight Drywall.
Dana's link to the "air-tight drywall primer" is dead.
Michael,
Try this link instead: Air Barriers: Airtight Drywall Approach.
