How close to the soffit vents under the eaves can I place my exterior wall rigid foam?
![](https://secure.gravatar.com/avatar/0c7107d85c15233f4ba04390e5febe4e?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
I’m doing a curtain wall retrofit, so even though my polyiso is only 4″ thick, I’m actually extended a good 8″ away from the original wall.
Anthony,
I don't understand your question.
First of all, if you are installing 4 inches of polyiso, why is your new assembly 8 inches thick? Are you installing brick veneer?
Second, as long as your new wall doesn't block your soffit vents, and as long as you have enough of a roof overhang to keep most of the rain off your wall, you shouldn't have any problems. But I'm guessing there is more to your question than I understand. Maybe you can post a photo.
