How can we calculate heat load from moisture added to system?
![](https://secure.gravatar.com/avatar/fed39250b3547edeff92e97449c2a09b?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Ft.png&r=g)
Dear All,
Suppose if there is indoor swimming pool area that we need to air conditioned, when we calculate heat load, we’ll have to consider vapour added to system. If the amount of water vapour added is M kg and the Dry Bulb Temp. is 27 deg. C. How can we locate this point in psychometric chart? or otherwise is there any other way to find out the dehumidification load of this moisture? Please don,t consider using of dehumidifier? I need to use normal Roof Top Packaged Unit. Please can anyone help me????????????
