How can I address condensation in my arched cabin walls
![](https://secure.gravatar.com/avatar/811ec5f6ce4ee45988e7776b016c30a5?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fw.png&r=g)
I built a 20×24 arched cabin(Gothic arch,2 inchsteel frame, 2×4 endcaps) in 2016. We were told that the provided insulation was r-49, but subsequent conversation with the manufacturer , solar gawd, said we are more like r 30, with two layers on the outside and two layers on the inside of the cabin ribs. We planned to make the end caps r 30 but the local contractor refused to install the rigid foam we had bought so we only have r 15 fiberglass in the wall. People here in our area of western North Carolina seem generally topay little attention to energy efficiency, so when a yankee, and a woman contractor, moves in, it is not easy to get willing help. The bottom line is that we have significant condensation . This is in the 2 inch rib bays. On the outside between the steel and solar yard, and on the inside between the solar yard and paneling. Since I have been building energy efficient homes since 1984, I find this quite distressing, as I was assured I had r49 . I believe part of problem with moisture. Is that we were supplied non perforated solar gard for the interior application.
At this point, and with limited budget I’m wondering if I can turn the rib bays into interior space by installing a vent at top and bottoms of each, and then use a lunos e2 HRV which is what the folks at rimland tales described using , along with a mini split which was in our plans.
I have also considered filling each rib bay with rigid spray foam, or perhaps mineral wool. We are very chemical sensitive , so somewhat reluctant to go with foam as we did that in a previous house and I believe it may have been done incorrectly so we had what I would call a “sick” house. I always felt better when I could drag myself out of the house. We can’t have that again.
At this point I am thinking of a Santa Fe dehumidifier, or a lunos 2e. And a small mini split that we can use primarily for cooling. We installed a vented Rinnai propane furnace that does a pretty good job of heating except in the bedroom alcove on the back side of the small cabin.
Any suggestions on the best way to correct this would be welcomed.
This is a double-post. The active thread is here: https://www.greenbuildingadvisor.com/community/forum/mechanicals/103477/how-can-i-address-condensation-my-arched-cabin-walls
