Housewrap question – replacing siding
![](https://secure.gravatar.com/avatar/e751201174f29554176b86bfd9a44f92?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fr.png&r=g)
I want to replace the siding on my house. It has wood (plywood) siding sheets on it.
I notice that it don’t have any housewrap. When I pull back the siding, I can see the installation. When I watch at some video about housewrap, they are tacking it to a type of plywood.
My question is, do I need to install the plywood are something before I put the siding on it? I need to know what is best, and what do I do when I get to the windows and door with the wrap. If you have any related videos send them to me.
Thanks
Myles
Reginald,
It sounds as if your house has T-111 siding. This is plywood siding that comes in 4x8 sheets.
If my guess is correct, you should probably leave the T-111 in place and put your new siding on top of the T-111. In effect, the T-111 becomes your sheathing.
You still need to install a water-resistive barrier (WRB) -- for example, housewrap -- between the T-111 and the new siding. You may also want to install vertical furring strips between the housewrap and the siding to create a rainscreen gap.
Your windows and doors need to be properly flashed. If all this is new to you, you may wish to hire a contractor who knows how to flash windows. If you are sure you want to do the work yourself, start studying up on the following topics: water-resistive barrier, rainscreen, and window flashing. You can use the "search" feature on the GBA site to help you.
Here are links to some GBA videos on flashing windows:
Flanged Window Video Series — Parts 2 & 3 (Robinson)
Extra Protection for Head Flashing on Windows and Doors
Flanged Window Replacement in a House with Wood Siding (1/5)
Pan Flashing Choices for Windows and Doors
Flashing the Jambs on Flanged Windows
Flashing the Jambs of Pre-Cased Windows and Doors
Head Flashing Windows and Doors with Preapplied Casing
