House wrap over Zip or Forcefield
![](https://secure.gravatar.com/avatar/49b1a9c0709bebfcb819963006f26084?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fd.png&r=g)
Is it possible to use a house wrap with a built-rain screen over Zip system or Forcefield sheathing without causing a moisture problem between the two barriers? I already have the house wrap and the house is being sided with LP smartside b&b.
As long as the product has comparable or greater permeance than Zip, you're not really changing the drying potential of the assembly.
djmissions,
Yes, but be aware that the dimpled house-wraps provide very few of the benefits a full rain-screen does.
There's this document from Huber about Housewrap.
https://www.huberwood.com/uploads/documents/technical/Housewrap-over-ZIP-System-sheathing-Tech-Tip-Wall-ZIP-System_2021-08-03-194820_dijx.pdf
They do recommend layers of housewrap for stucco but I don't know if they require it for other types of cladding.
I know there's a Huber Peel & Stick product for roofs but I don't know if it can be used for walls.
https://www.huberwood.com/uploads/documents/technical/ZIP-System-Peel-and-Stick-Underlayment-Sales-sheet-SEC.pdf
