Horizontal furring strips on rainscreen around windows
user-7005952 | Posted in General Questions on
I am having my siding and windows replaced. As part of this project, I specified that a rainscreen be installed. When reviewing the work today, I noticed that they are installing horizontal furring strips above and below the windows. Is there any reason to be concerned about the strips above the windows inhibiting drainage?
I found several discussions of horizontal rainscreens on the site, and I assume this would not be much different from that.
Also, as you can see in the pictures, they decided to use a drainage wrap, HydroGap, in addition to the rainscreen. I suspect this further ameliorates any concerns.
I already have several unrelated issues that I have brought up with them, and I would prefer to not raise this if it is a non-issue.
Thank you,
Greg
    MALCOLM TAYLOR | | #1
    I wouldn't be very worried about the strips. Ideally the vertical ones both below and above the window are kept off the sill and head a bit to allow some air movement, but it isn't critical. What is a problem is that the head-flashing should be behind the rain-screen and be lapped by your WRB. The only time flashing gets mounted on top of the rain-screen strips is where there is a horizontal change in siding materials or trim.
  2. user-7005952 | | #2
    Malcolm, thanks for bringing that up. I hadn't thought that far ahead. I will raise that with them.
    MALCOLM TAYLOR | | #3
    Greg,
    From the photos it looks like an easy fix. If you remove the horizontal furring above the windows, you can install the flashing and it leaves a space for air to circulate.
  4. JC72 | | #4
    If you want to get really fancy with the flashing details.
    https://hammerandhand.com/best-practices/manual/4-rain-screens/4-2-top-window/
