Hi, I need to have my windows replaced and eventually new siding.
![](https://secure.gravatar.com/avatar/a012dbe961650ff850de955dfd75c271?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fh.png&r=g)
Herrmy
Which way should go first, get the siding done or replace the windows? Thank you
I probably do the windows first. If you install the siding first, you would have to redo some of it when replacing the windows. You can install, flash and waterproof your windows easier, and thinking ahead when you moistureproof your walls later.
Holger,
Don't forget to consider upgrading the R-value of your wall: Roofing and Siding Jobs Are Energy-Retrofit Opportunities.
