Heating System for Older Home
![](https://secure.gravatar.com/avatar/da7eb6de19191ee0c395112b1ea311c2?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fi.png&r=g)
Our home had an oil based heating system. We’ve removed it as part of an extensive renovation and are looking at a few different options. We have a natural gas available. We live in the Boston area and the temperatures can get cold. The general contractor recommended a hydro-air system as it provides a comfortable heat due to the humidity and can also power water based radiant flooring. I was reading about heat pumps, but am concerned about inadequate heat and poor efficiency when temperatures drop. I learned about dual fuel heat pumps (a heat pump that has a back up natural gas furnace for when temperatures drop) and was wondering if that’s a better way to go? Open to other alternatives!
Don’t let the GC anywhere near a boiler :). Hydro-air has no humidity benefits. A hybrid heat pump / furnace would be perfect for your situation, especially if you’re planning for AC. A cold climate heat pump only would also work.
There is no "best" HVAC system, we all have different desires, building/physical restraints, budgets, ideas on comfort and efficiency goals. Interview the best HVAC companies in your area and see what options appeal to you. Call the major HVAC manufacturers and ask for their local top dealers. Read reviews, talk to their sales people, ask to visit their shops. Are their techs/installers NATE certified? Factory Authorized dealers? You notice these forums are heavily biased towards HP's and they can be a great option, however they aren't always the best solution when all the information is gathered. Whereabouts in the Boston area are you? I may send you some referrals?
Hi Richard! I really appreciate that and would appreciate a referral. I am in Brookline.
Call Atlantic Heating & Cooling in Brookline and ask for Darren Chapman. Tell him Rich from Central Cooling sent you.
