Heat pump in a vaulted living room?
![](/app/themes/greenbuildingadvisor/_assets/img/avatar/avatar_50x50.jpg)
Hi,
I’m wondering if anyone has any experience installing a heat pump in a vaulted living room? I ask because I’m wondering to what extent a higher ceiling would affect its ability to heat the space. I should say: installing a ceiling fan isn’t an option, unfortunately.
The attached drawing isn’t 100% accurate, but it should at least give you a sense of the layout. The red x’s are spots where a head won’t fit; the green y’s are possibilities.
I also wondered whether a floor console might be a better option, but I wasn’t sure (there’s actually only one spot it would fit because of the baseboards).
We’ve had a few companies through, and opinions have varied, so I suspect it’s just a challenging space to configure.
Any thoughts would be appreciated,
Dave.
