Heat pump
Edjacoby51
| Posted in Energy Efficiency and Durability on
Why can’t a air to air heat pump use the air from a basement instead of using the air from the exterior.
Because the basement is connected to the house, any heat you pull out of the basement you're pulling out of the house.
