Has the Roxul sub slab technical bulletin been axed?
![](https://secure.gravatar.com/avatar/bdb5cb691ec733567453079262e8d2de?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
Back in May, there was a posting that Roxul will be publishing a technical bulletin about sub slab rockwool insulation. So far, I haven’t seen anything from Roxul. Is anyone aware if the bulletin is still in the works?
–John
I contacted Thomas Hackett at Roxul and he emailed me the Technical Bulletin via PDF on July 02, 2015. It is still very much alive.
