Has anyone used the Multi-Panel SIP product?
begreener | Posted in General Questions on
excerpt:
M-SIPS is a building system panel consisting of a high-performance insulation core (polyurethane), sandwiched between two layers of M4 structural noncombustible composite panels (magnesium oxide with fiberglass).”
They come in 4” — 11” thick SIP panels with factory installed internal structural studs – either:
* fiberglass reinforced plastic
or
* standard steel (C studs)
They use a simple surface spline, so each standard panel can very easily be customized.
They can be used to create walls (loadbearing and non-loadbearing), roofs, foundations.
