Has anyone ever used stacked IGUs in a homemade window?
![](https://secure.gravatar.com/avatar/75165729082af5d1a54c9359eff7ea3c?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fc.png&r=g)
I’m building a shop for my small construction company and have some insulated glass units that I saved from previous jobs. Has anyone ever used stacked IGUs in a homemade window?
I was thinking of making one removable like a storm window.
Chad,
I'm sure someone has done it.
I've built plenty of fixed windows using IGUs. However, all of the windows I've built have been double-glazed (with one IGU). I have never tried to assemble a fixed window with quadruple glazing (made from two IGUs).
The usual problem with site-built multipane windows is condensation between the glazing layers. The easiest way to avoid this problem is to stick with windows that have just one IGU.
Building a removable storm panel to hold an IGU is a lot of work, and I'm not sure it's worth it.
Martin,
Thanks for the response.
I used a different search term "storm windows with IGU" and found some over comments. Heat may also become a problem. I only have two windows to build so I think I may experiment with this idea, I have the glass.
I have done it.
On the sunny side, you will get condensation in the winter, but it goes away when it warms up.
I would use simple weatherstripping between the units so you can take them out every X years and clean them
In the shade, not many problems, slight blush when very cold, goes away quickly
