Half height Blueskin for a foundation?
![](https://secure.gravatar.com/avatar/af3bebe71f9f0cb70a16d5bea8fdd475?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fc.png&r=g)
I’m installing perimeter drains around my foundation, 4″ PVC drainpipe with a run to daylight.
I was thinking of waterproofing my foundation with either a roll/brush on rubber compound or the Blueskin membrane.But I don’t trust the brushon stuff down at the footing where the concrete blocks form a seam.
This is where the question lies….here in Canada the Blueskin is pretty expensive so I don’t want to use it except where needed, and I can buy some brushon waterproofing compound at a great price.
I want to run the blueskin up from the footing/cement block joint up the wall about 2-1/2′, then roll on the waterproofing compound the rest of the way up to grade, (2 coats) then install delta dimpled membrane in the normal fashion .
Does anyone think the water would/could make it under the blueskin?
All peel and stick membranes need to be terminated at the top. What you are proposing is technically a reverse lap. Blueskin folks I think sells specific compound for this.
The amount of extra work for this half/half setup will probably cancel out the savings. If you are worried about water, than go with a full height peel and stick. Simpler and guaranteed to work.
Ok, thanks. I think I'll go with the full Blueskin then.
If you are really worried about the cold joint between the footing and the foundation, there is a solution for that: waterstops. See this GBA blog: https://www.greenbuildingadvisor.com/article/petes-product-puzzle-cetco-rx-101-sika-703.
Peter
