Gutted Brick Home – Replacement window type – Flanged or NonFlanged
![](https://secure.gravatar.com/avatar/0cfec1ce67951c2e40583649873140d7?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
Hello,
Thanks in advance for the ideas.
We are replacing all of the windows in our gut rehab of an 1880 brick home in Northern Michigan.
1/2″ is the greatest measurement any of the window frames are off square.
Do we:
1. Replace with flanged windows, build four sided pressure treated buck, using sealing tapes, spray foam and then finishing over the exterior perimeter gaps / build up with aluminum and caulk bead sealing window to brick surround.
2. Replace with Non-Flanged and fasten through window frame directly to brick with strapping and a (slightly) larger bead of caulk sealing window to brick surround.
Option 1 will provide more barriers between exterior and interior to prevent water and air infiltration but will reduce glazing (relatively) significantly.
Option 2 will increase glazing (relatively) significantly but will reduce our exterior barrier to a single caulk bead.
Thoughts?
Thanks very much.
SB
