Grade level door in a REMOTE Retrofit
![](https://secure.gravatar.com/avatar/ba7bc2bedbea1aeb4e64b924a0f2df77?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
I am installing 3 inches of rigid foam board to the outside of my 2×4 frame house following the REMOTE system. Over the foam are 1×4 furring strips followed by vinyl siding. I have taken out all of the original windows and doors and installed 2×6 replacements (adding framing around the doors and windows to the proper width). My problem lies with the last door that I am replacing… a grade level entry door to the garage. The foam I am adding is only going down the wall to the sill plate (not adding below grade insulation to the exterior crawlspace: too much money for all of that). Any ideas on how I should deal with the transition from the 3 inches of foam (plus 3/4 inch rain screen and the vinyl siding) to the existing foundation?
Also the framing for the 2×6 door would be sticking out approx. 2 inches. I assume this is a no-no because ground heaving (I am in Alaska) will not affect the foundation but will affect the grade. I could utilize a 2×4 door but I would still have the jamb extensions sticking out.
Thoughts? Advice? Thanks!
Use an inswing door.
